SpotlightModifying trusses and systems
The truss context menu provides options for selecting and editing truss objects or entire systems. Right-click on a truss object in the drawing, and select the desired command from the context menu. Many of these commands are also available on the Object Info palette.
Command
Description
Customize Truss Symbol Data
Opens the Truss Properties dialog box for Modifying truss symbol data
Select Objects of Same Symbol
Selects truss objects with the same Symbol definition
Select Objects of Same Cross Section
Selects truss objects with the same Cross section parameter
Select System Objects
Selects all truss objects connected within the same system, along with all associated loads, hoists, and so on
Change Trim Height of System
Opens the Change Trim Height dialog box for Changing the trim height of a system
Change Configuration
Opens the Change Replace Truss Configuration dialog box for Replacing truss configurations
Rename Truss System
Opens the Change Truss System Name dialog box for Renaming truss systems
Convert to Hanging Position
Selects the entire system, including the truss and any connected rigging objects, for conversion to one or more hanging positions. Any attached loads are associated with the created hanging position(s); see Creating a hanging position object.
Custom shortcuts can be assigned to the commands; see Modifying commands and tools in a workspace.
Concept: Braceworks structural analysis
Placing trusses
Concept: Rigging objects
Concept: Attaching loads to rigging objects
